sledders New member Joined Mar 15, 2016 Messages 25 Age 90 Location Melrose MN Feb 24, 2017 #1 This for XSR 2000 which has no battery, presume AC to head light. If so will the LED work without inserting a diode to smooth out the sign wave?
Y Yamahasrx700 Member Joined Feb 11, 2004 Messages 617 Age 58 Location Channaho, Il. Feb 25, 2017 #2 This is the one I have on my 97 SX700. Its awesome https://www.cyclopsadventuresports.com/3800-Lumen-H4-LED-Headlight-bulb-_p_83.html
N NorthernSX New member Joined Mar 6, 2017 Messages 103 Location nd Mar 6, 2017 #3 Yamahasrx700, which version do you have ? 7000 Lumen ?
Y Yamahasrx700 Member Joined Feb 11, 2004 Messages 617 Age 58 Location Channaho, Il. Mar 10, 2017 #4 I got the 3800 but why not upgrade to 7000 for only $10
N NorthernSX New member Joined Mar 6, 2017 Messages 103 Location nd Mar 21, 2017 #5 Do you need the rectifier for $19.95 ?
Y Yamahasrx700 Member Joined Feb 11, 2004 Messages 617 Age 58 Location Channaho, Il. Mar 22, 2017 #6 If you tap off the factory "back up alarm" wire then you don't need the rectifier. The back up alarm has a rectifier to give clean DC voltage.
I imder1ck New member Joined May 21, 2014 Messages 11 Location Minnesota Aug 11, 2017 #7 Is the 3800 Lumen version bright enough? I'm thinking of getting one.
