AttakMax
Does anyone have pics or suggestions on the mounting bracket or system used to retrofit these into the SRX chassis? I'm fabricating my own brackets and looking for pics to point me in the right direction. Thanks.
Perfect, thanks. However, do your floats have the clevis top mount? I'm using SX Viper Ohlins with the clevis top mount to go on a SRX that uses a standard eye top mount.View attachment 62979
http://www.yamahapartshouse.com/oemparts/a/yam/5003bb0df8700212fc83fa11/skiWhat spacer are you referring to?? I was looking at the parts fiche with regards to that bushing. Just trying to figure out how to make it work.
SRX is a different setup than that. The bracket that is used to attach the shock top to the chassis is bolted on with two bolts.
Thanks for the pic. Is that just an old shock top mount welded on a plate?
