the advantedge helix is what caused your problem, those helix shift more aggressive then what they are stamped due to the radius on which they are cut, its really comparable to about 55/47, which would overshift the clutchs with 8bu front weights and the soft w/w/w primary spring. Kinda think of a stick shift car, you drop the clutch and go from first gear to third gear, it bogs, low on rpm and takes a long distance to recover lost rpm and come back into the powerband of the engine.
To remedy the problem with the parts you already have on hand, I would use the stock primary spring in front clutch the y/w/y and then youll be able to add some tip weight back in to bring the rpm to 8500rpm.
Your other option is to use a smaller helix angle, something more in the line of a 50/44.
