brnleva
does anyone know what rpms I should be at while cruising between 30-40 mph is there a chart ? or how do I know if I'm
too high or too low
too high or too low
It is all relative to your clutching components and wear, drive line wear and clutch cleanliness. I believe your Max rpm should be ABSOLUTELY no higher than 8000. Prime rpm is 7800. Or that's what's coming to mind. Someone w/ a 97 and up twin will chime in and clarify. My 96 is a different designed twin.does anyone know what rpms I should be at while cruising between 30-40 mph is there a chart ? or how do I know if I'm
too high or too low
