Maim
Super Moderator
i have thought about doing this to my et410 with the same chaincase. the master cylinder and brake light switch can come from any sled. the caliper from the front of a motorcycle will probably work the best as the rotors are similar thickness. i would go with a single piston caliper in the 9-10 oclock position with the piston over the exhaust for clearance. then i would fabricate a bracket to mount the caliper to the existing brake system bracket location.
i helped a buddy do this on an old skidoo he was setting up for ice drags. we used an xt 350 caliper and pads on the stock rotor with a master and like from a formula plus he had hanging around for parts. i would have to go through my stuff and see if that caliper would have the bleeder screw in the right position for that sled.
Maim
Super Moderator
that is why i suggested a bike caliper with the piston out over the exhaust in around the 10:00 position on the rotor.
https://i.ebayimg.com/thumbs/images/g/TBcAAOSwqU5Zw-3e/s-l225.jpg.
they have more clearance than most sled calipers i have seen in how they are made. it looks like you need one from the right front on a banshee from the pics i have seen. once you have it mocked in place, you then fabricate a peice of steel that connects on its mounting area to the origional mount point for the cable brake. run line, bleed and hook up brake switch on bars.
Here in Sweden it's impossible to get a Banshee caliper since it not sells here.I suggest to use a bike caliper with the piston out over the exhaust in around the 10:00 position on the rotor.
They have more clearance than most sled calipers I have seen in how they are made.
It looks like you need one from the right front from a banshee from the pics I have seen.
Once you have it mocked in place, you then fabricate a peice of steel that connects on its mounting area to the origional mount point for the cable brake.
Run line, bleed and hook up brake switch on bars.
I have looked at a Polaris RMK "PRO" caliper because of its small compact size.
Your thoughts on this ?
Maim
Super Moderator
yes that caliper would work. it looks thin enough and bleeder is in right spot.
Mounting bracket... ?
I now have got a Polaris RMK "PRO" hydaulic brake caliper and have started to look how to mount it on the Venture gearcase.
I will have to shift the brake disc around to make it accept the brake caliper.
It is very limited with space and there is actually only one position where the brake caliper can be mounted.
Please share your ideas how to make a mounting bracket.
I have done conversions on Vmax 4 and used SX-R or SRX brake parts and line and handlebar controls. Trick is making a parking brake that works.
opsled
Did this for TSS Vmax 92-96. Same concept may work on other sleds.
https://totallyamaha.net/showthread.php/88900-Hyd-Brake-conversion-for-Vmax-500-600-Vmax-4
opsled
opsled
I have some calipers and controls from some SX and SRX. You would have to make your own mount plate. I might even have a few disks if you wanted to concert to a bigger disk.
Thanx for your offer, but I'm in Sweden.I have done conversions on V-Max 4 and used SX-R or SRX brake parts and line and handlebar controls.
I might even have a few disks if you wanted to convert to a bigger disc.
Parking brake is no problem, Im already have got the brake master cylinder from an Ski-Doo XP and the brake caliper from an Polaris RMK "PRO".
Problem for me is the very limited space since the sled have Reverse gearbox.
opsled
