Both bolt and threaded hole need to me cleaned of any oil with brake cleaner and then let to dry before installing the bolt with locktight. Don't use red stuff it's too hardcore, blue ( removable) is plenty. Also locktight does require a few hours to cure before being put into service and in cold weather like freezing or below the locktight may never set. So warming things up will help the curing process.
