boringnh
Hi,
New to the forum here! I have been another brand name rider my whole life, but I picked up a 91 Phazer for my kids. I am excited to hit the snow with it. It runs and works, but needed some carb work. The air mixture screw on the PTO side was snapped off. Long story short it is not coming out. Also, I have a jet that will not come out. I am looking to replace them. Is there another model Yamaha that had the same carb set up or am I limited to the Phazer carbs? Any info or insight would be greatly appreciated.
NorthofSixty
The Yamaha Ventures used the same engine and carb set up in those years. A set of Phazer/Venture carbs is usually pretty easy to find as they were used for several years.
boringnh
Thank you. Do you know if the earlier Phazers carbs would work? Found a set locally.
Yamaha Nutz
85 -97 phazer/ venture carbs will work 84 phazer carbs can work too but have no TORS switch system
boringnh
Thank you!!!
