what is the cc u get with the head install vs the head only ...i try to know the cc diference
			YAMMIEGOD3:16
the cut you made vs what a stock head is cc ed at his alot. when you get this motor together you will need to do a squish test right away. 3:16x (yammie tony)
i open up the head some ...its a set of head i had with a ported cylinder ....
Mac
I have never seen anyone ask that question here on this forum.  To calculate yourself smear a small amount of wheel bearing grease around the edge of the piston @ TDC.  just enough to prevent the water from passing by the rings.  Then cover the cylinder with a small piece of plexiglass and seal it to the cylinder with grease.  Drill a 3/8 hole in the plexi.  Fill the area with water and note the cc amount.
---mac---
			---mac---
---mac---
Thnx mac ...i ask since i was not home...and try to figure out ...i got my anwser since i put the head on and fill them with water
YAMMIEGOD3:16
high high octane motor. 3:16x (yammie tony)
