thetorches
Hello. My viper died on super bowl sunday. I checked compression and center cylinder was 15 psi. Other two are okay. Finally got around to removing head. Center cylinder scored. It looks like the piston was loose and hitting the head. Head has marks on it. When I compress the center piston you can here a clunck, like there is a space between piston and connecting rod. What could cause this. Could the piston pin have broken. First time doing this so any info would be appreciated. Thanks.
