Motodeficient
I want to ditch the .91" stock track on my 03 SX Viper. I want to put the biggest lug track I can on without switching drivers.
Can I run remove the tunnel and heat exchanger protectors and run a 1.6" Ice Cobra track? It has the little studs built into the ends of the lugs..
https://www.tracksusa.com/productde...3261&referrer=https%3a%2f%2fwww.google.com%2f
If not, a regular 1.5" track like the intense would work without studs, if I remove the tunnel and heat exchanger protectors, correct?
Whats the biggest unstudded track I can run while leaving the tunnel and heat exchanger protectors?
