Holenov
I locked up my drive chain on my 03 Viper, was going to change it myself, is there a good manual or a post for this, its got reverse and I was told to take a lot of pictures, any other advice would be appreciated
yes that bearing is toast. royaldistributing as well as your local dealer should be able to get the all balls kits that have all the bearings and seals to do the jack shaft and drive axle bearings on both ends.
from the online pricing it looks to be about $37.00 for the jack shaft and $40.00 for the drive axle.
you can do it pulling the track but i do not see the need. just pull the chain case off once you take the tension out on the track and leave the drive axle in place. should be able to replace the spedo bearing in place if the shaft is good.
I'm having a heck of a time loosening off the track too I've loosened the bolts 10 rotations but cant get the axle to slide forward ?
