Motodeficient
Hey guys, I am in the middle of removing the track on my 03 viper. Trying to pull the chaincase but I'm stuck on how you are supposed to remove the parking brake from the chaincase and brake disk. There is a long bolt that goes through both "scissor arms" of the parking brake and also two springs... do I remove that? It looks like there isn't enough clearance for that bolt to pull out if I try to remove it though, as the head of it is very close to the metal coolant line that comes up from the heat exchanger.
