Motodeficient
Putting new bearings in while I have the driveshaft out for a track swap.
There is no grease fitting on these sleds for the speedo side bearing? Old bearing was pretty dry. Do I grease the bearing somehow before I install it on the shaft? I will put some anti-sieze on the shaft itself but on every other sled I have had there was a grease fitting on the speedo side bearing.
