Craig Jaremczuk
Hi everyone, so I picked up an 85 ss440 in great condition. I pulled apart the carb and cleaned it very carefully with carb cleaner and compressed air. Clean air box. New plugs. Filled the oil res. Checked compression and both cyl are just over 101 psi. Primed float bowl in carb and gave it a few pulls to see the fuel pump fill the lines up. Put the plugs to the block and pulled and both seem by eye to be getting spark. Engine won't start at all. At best has a weak sputter but only once in a while. Mainly nothing. Gave a small shot of starter fluid down the plug holes and barely did anything. Cleaned carb a second time, checked spark again to find them still showing signs of spark. Also forgot to add that every few pulls I take out the plugs and they seem to be getting fuel so I dry them off and try again. Randomly got it to fire while no choke and throttle applied, ran for 30 seconds sounded healthy then just shut off and back to having nothing. Where would you recommend going from here. I don't want to buy tons of parts for trial and error. Hoping someone has seen this being it's a common older sled. Thanks in advance for help
