Ran the sled last season, was running fine when I parked it, started twice during the summer started it for a few minutes, last week I stated it and ran like crap, I cleaned the carbs it was missing at low end, found some dirt in them, reinstall the carbs and ran for a few minutes at slow speeds, 20-30 km/hr , then felt like it ran on 2 cyl, some backfire in the exhaust, shut it off right away , thought maybe that there was a mice nest in the exhaust, so I removed the exhaust to find that #1 wasn't firing, exhaust on that cyl had unburnt gas and oil in that port, very dark and wet compared to the other 2, no mice nest in the exhaust, I was thinking coil , pickup, stator? anyone had a familiar problem? Tx all!
Also compression is good all across 120psi, I also read about harnesses rubbing under engine for 01 srx?
RXMax
Good Spark on that cylinder? Needle valve might have failed on that carb causing excess fuel
HDYAMAHA84
carb or coil pack is where id look first
Srx007
I would start by replacing the spark plugs, you probably fouled one. Also, before you replace them you could switch the plugs around and see if the problem follows that plug
YAMMIEGOD3:16
get into your carbs for starters. you took away chance it was mice. the cyl that is not running, try switching coil wire and see if problem jumps to another jug. 3:16x (YAMMIE TONY)
Scarpino
It could be the spark plug cap/ coils
drew24
I would also guess its a bad plug cap.
Mortagleus
I just had very similiar issues a few threads back. Was plug caps on mine
