nick5oh
Found this nut under my secondary chillin on the belly pan near the coolant hose...what’s it for please help???
Photo upload failing
It’s a13mm nut with spinning washer built into it? What’s it for please help?
nick5oh
It may be possible that I dropped it down there however I am a bit paranoid. Previous owner had a nut like this securing the rear bumper bar to the tunnel. Like I said I’m paranoid right now. I’m doing my check over for the season....chain case oil, plugs, clutch service, belt, pv clean/check/adjust, carb clean etc etc all the fun stuff. Found the nut sitting there
I can’t upload the photo for some reason
nick5oh
Upload of file failed!��again!!!
A couple of bucks
Not that I can see it, check the secondary bearing housing.
A couple of bucks
Don't crop the picture.Upload of file failed!��again!!!
nick5oh
I didn’t crop the picture. Still won’t work
This never happened to me when I had an iPhone 6...now I have a iPhone 7plus. Maybe picture quality/size is too large?
you have to use an image resizing app to get them to upload or take the picture through the tapatalk app whitch resizes them correctly automatically.
A couple of bucks
I still have my old 5. If I crop the picture, I cannot upload the cropped one. The original goes through just fine.I didn’t crop the picture. Still won’t work
Yamahasrx700
I dont think Yamaha uses a 13mm nut on anything. Even my MX bike has even wrench sizes 8,10,12 and so on. Except the radius rods to chasis that are 17 and 19. IDK
nick5oh
It honestly looks like a body nut-I’ll call them that being a mechanic.
Nut turns and washer stays fixed. I didn’t think yammy uses a 13mm either. Just the 8,10,12,14,17, and so on
nick5oh
A couple of bucks
Reflector?
Srx007
Im pretty sure that is the hold down nut for the muffler which is located just behind the right foot well, a real bugger to get at.
nick5oh
Anything’s possible but I found this nut on the left side on the belly pan under the secondary
nick5oh
Voila! That is exactly what the nut looks like however mine is still there and also I found it on the left side of the sled/clutch side.
