M-10 weight transfer
vmax700sx
I did resolve my darting problem thanks to the darting article in the tech section. (Thanks to Vmaxjohn and Mr sled for their input).
Now I would like to see if I can do anything about all the track spin I am getting. I seem to remember there was some talk about improving weight transfer on the M-10. Any suggestions?
the block in the back you can cut off about 1/4" or call fast and get the white blocks, but in order for this to work really well you need to soften the skid.
Mr Sled,
When you say soft are you referring to the FRA adjustment? I believe it is set on 2
As for the blocks do you mean the slider block? They have 2 different sizes?
Do you have a part number?
Thanks for your help.
Yes set the FRA to the softest it will go for racing and yes the slider blocks, they have a white block that is shorter, they run them in the RX1 m10 and long skids and the black blocks on the 121" skids. Give them a call to order or trim the black blocks down some.
