Picked up an 02 Viper recently and am getting it ready for a trip. Topped off the oil over the weekend and today when I got home from work noticed 2 stroke oil under the sled. It didn’t leak before topping off the tank and I was careful not to spill. Any ideas what I should be checking? Thanks in advance
super1c
Super Moderator
Take off airbox and start checking all your lines. From oil reservoir to pump to engine ect. Make sure bleed screw is tight also. That’s in between center and clutch side carbs.
False alarm. I had bought a gallon of oil, filled the tank, and set the gallon on the running board. Turns out the bottle had a split in it and was leaking down and dripping under the sled. Whew!
super1c
Super Moderator
Those are great surprises to find. Easy fix!
