In short: 2001 srx 700
Symptoms: Starts for two seconds then CDI is cutting ignition (I can see the spark killed through my test light). If you keep RPM above 4000 it will run, but CDI kills it as soon as it reaches idle.
New: Coils, CDI, Stator, pickup coil, voltage regulator/rectifier
Checked: Condensers, load control relay, head light relay, every inch of wiring harness on the sled, unplugged head lights, bypassed all switches, unplugged hand warmers, even applied 12 volt battery at voltage regulator to force 12 volts to the CDI... all the same result starts for 2 seconds then ignition dies...(if you force the 12v into system with a battery you have to disconnect is before it'll start again, this tells me the CDI is cutting (and holding) spark for some reason)
I know there is a 2001 tech bulletin about adding an additional relay/harness for something similar to this, due to load demand at startup, but unplugging headlights would remove any load...and I did that...no change
It won't start with speedometer unplugged, CDI must need that to run bit check with the temp light ...that's the only/last component that could have a short?
I've got hundred of hours in the POS...does anyone have any other ideas before I burn it and post the video on youtube?
