stubby
Hi all..I have 1989 Ovation 340cc fan cooled that I rebuilt. That seems to have gone well, I had the cylinders bored and honed .020 over, and put in new rings, pistions, pins, bearings. Totally disassembled the carb, cleaned that, new gaskets and set everything to original specs (air needle, throttle screw etc.) Even went nuts and drained the chain case and tightned the chain, new gasket, oil. All is good. Even checked the brakes..I know Iknow...routine maintaence for you guys! LOL...here is the problem...I put a new belt on the machine and the motor only runs when the machine is lifted off the ground. Try and hit the brake and you stall the motor. I know this sounds like a bad primary clutch for my little mind, but I did work it back and forth while everything else was disassembled and I am baffled. Could the main spring just be weak? Its a totally stock machine and has probably 3500 miles on it. Sometimes I hear a metalic tinging noise, almost sounds like a bell...clutch? I sure hope its not my new cylinder job! I have no tools to get the thing off other than wrenches and sockets. I have to get this thing running and get another Yamaha sled into the garage to figure out why its eating belts, but thats another story! Thanks in advance...we have a trip planned the 3rd week in January for the UP of Michigan...hope to get this resolved...Merry Christmas.!!!
