Exciter570
Hi guys,
Is there any difference between the subject motors? The engine in my 95 with GYT twin pipes failed and will need 2 replated cylinders, pistons, etc. and I've been advised that with over 9000 miles on the sled that the crank should be rebuilt as well while things are apart. Instead of going the rebuild route which will run ~$2k parts & labor I am considering putting in a low mileage donor motor. I have a handle on a low mileage 97 600 twin but don't want to pull the trigger on it if the 97 motor is different and will cause problems and/or I won't be able to run the GYT twin pipes.
I appreciate your insights,
Chris
Chris
