Any luck with the 50 pilots mod
It fix the bug .....thnx again for the tip...lets race tomorow
Vincent
Awsome!
A couple of bucks
Action vids??
Action vids??
No video ...race was on snow ...had to switch the helix to 80 degree cause it was overshifting ...sled pull awsome just need more tuning
This setup I ran in my SRX when I used heel clickers
40-10
Red primary spring
5 grams in heel
8 grams in tip
Mid empty
50/38 dalton helix
Silver @ 60 and 70 depending on conditions
21/40 gearing for 660ft
1.25 track
140 mains
50 pilots
40-10
Red primary spring
5 grams in heel
8 grams in tip
Mid empty
50/38 dalton helix
1.25 track
140 mains
50 pilots
40-10
Red primary spring
5 grams in heel
8 grams in tip
Mid empty
50/38 dalton helix
1.25 track
140 mains
50 pilots
I will change my gear to 22-39 ..not sure if i can add alot more than 5.5 gram in heel ..rpm is close to 9000 ..i dont wanna add in tip sled seem to pull hard at 600' feet
Green or gray secondary spring with heel clicker on snow ....52.38 dalton seem to want to shift so fast
Lack of speed at 400 feet. ...4 gramm heel 5g mid and 3.5 tip ...sled pull awsome till around 400 feet then it seem flat ..other sled start to catch me ..22.39 gear ...should i move more weight to the tip ....grey spring at 70...maybe i should remove some of tip to make the engine torque less on top ???
Corey9965
Did you put your fuel screw back to 1.5-2 turns out? Maybe as your transitioning between jets it’s a little too “rich”? I don’t know how much of a difference it would make as I’m still learning myself. I saw that you made the jump to 50’s. Just didn’t know if you turned the fuel screws back in.
