ViperBite20
02 sx viper non er model.
New oem stator and coil pack.
Cleaned clutches and tried different belts
Cleaned carbs idles good runs good but at wot it will sometimes pull 8500rpm to 100+mph. Other times it runs 8500 then drops to 7000-7500 or maxes out at 7500 from the start.
Any ideas?
Any ideas?
RXMax
IF you can swap CDi with another viper
Yamablue
Powervalves, have you cleaned or adjusted them lately?
powervalve clean and adjust and see what the belt width is, a worn belt will lower rpm as well. new the belts are 34.5mm wide, check yours.
JERSEYJOE
Agreed. Power valves not working will do exactly this.
Any ideas?
I have seen sleds with broken motor mounts having an erratic full throttle RPM like you are experiencing.
A weak or broken secondary spring or a polished or wet secondary sheave surface can cause the belt to be puled down too deep in the secondary putting the clutches in to high of ratio as well.
A couple of bucks
ViperBite20
I pulled power valves and cleaned them and the ports very well. Still same thing even readjusted them again to make sure they where right. I'm thinking it's clutch related
is the clutching stock or modified?
ViperBite20
It's got a hauck helix and green and orange spring in hole 6 I believe. Buddy's sled that he bought like this ran great till this year. Could it be shifting out too soon and need the spring wrapped tighter?
Yamablue
Secondary spring could be junk.
drew24
I had this happen on my viper a couple years ago. I could barely get it up to speed and once in a while it would rip like it was supposed to. All I had on hand was a new green dot secondary spring and a new 51/43 helix so I swapped to see what would happen. It was good to go. Not sure if it was the spring wore out or the bushing in the helix but it was definitely one of the two. Not sure how old or used the parts you have but it could be the same issue. I would try a new secondary spring.
ViperBite20
Would you have a part number for the green spring?
Idk what kind of spring is in there now the whole thing is green and has a patch of orange that looks like someone did with a spray can
ViperBite20
90508-556a2
Thanks ordered a spring we'll see what happens
ViperBite20
Finally heard back from hauck apparently it's a straight 49 helix and recommend stock spring or their silver spring.
Stock spring would be a red one correct?
drew24
Yes. Stock is red.Finally heard back from hauck apparently it's a straight 49 helix and recommend stock spring or their silver spring.
Its actually black with a red stripe. part # 90508-536A9
