2 blinks temp light 00 srx 700
hessracing
Iron Mountain Michigan
Hey guys i got a goofy one going on here when i start up i get 2 blinks then nothing... runs great! power valves are adjusted properly nothing is sticking and servo does its clean on start up, i know its supposed to be 3 blinks, 2 blinks is grip warmer short i changed a hand grip on it last year but even before this it only blinked twice. hot grips work like they should no rub through in the wiring and plugged in like necessary, and the machine runs like it should any clue why it only blinks twice? is this a 2000 thing?
I have had issues with variable resistors causing light to blink. It is supposed to blink once for this fault and repeat . it is possible this is what you are seeing. The variable resistor is open at the back and I sprayed some contact cleaner and compressed air in to it to clean it and no more code
