SRX 700 low compression
Do they make special wheels for aluminum? The 3" cutoff wheels I'm using worked well for the first inch of the spider now its getting loaded up and not cutting.
Find a piece of scrap steel and use the wheel on it to clean it.
Clutch is cut off finally, motor is somewhat torn apart now. Any opinions on the piston and cylinders? https://postimg.cc/gallery/2zqe22wja/
There is some scratches on the nikasil, not really sure what to think of it. Send them off to USChrome? 3 cylinders x ~$200 is more than I really want to spend for this sled
One piston seems bad (the pto one). I remember a mouse nest on that cylinder, and I tried to get all the crud out but that must be where the scratches are from (and the pitting near the top of the piston).
