FinnishMotorFreak
Hello.
I own a 2003 Yamaha sxviper and it sticks to the ground like no other sled. what mods should I do to make it wheelie? I don't have the money to buy a fresh 44mm track, triple pipes and clutch kit so I will have to go with tuning the skid and I need help with that.
Second guestion: How much do I have to mod the hood of a viper to fit the srx pipes under there? If I end up putting those pipes do I need a rear heat exchanger? jetting is neede.
Srx pipes is a major under taking, if you want to wheelie let the limiter straps out for sure, I bet you could adjust the transfer rods also. I no longer have the proaction skid but give me a minute I can prolly link something.
https://vimeo.com/20218037
https://totallyamaha.com/snowmobiles/aaTECH/Suspension/specs/suspensionspecs.htm
https://totallyamaha.net/showthread.php/96974-How-do-I-set-my-sled-up-to-do-this?highlight=wheelies post 11
Also check your rpms, most sleds over rev.
https://www.google.com/search?q=bet...ZAhUHZKwKHSh0BRUQrQIIMCgDMAA&biw=1366&bih=637
devinzz1
skid swap, big lug track, mild motor work, lots of clutching, lightweight everything.
