Bought some Hauck Venom head, actually i wanted just water rail so i can fit it to 780 so i don't have to mod that what i made earlier. No motivation for dirty aluminiun welding��
I think i could use that on my 700, mut dome size is 19cc. So i think it is way too stiff. There was some detonation or something on one chamber so i used lathe and i took littlebit off. I know it changes squis, but if i want to use those i think i need to get dome size something like 21cc...
And i also broke my chaincase, because chain broke down... It was a fast fix, i have a sparepart in my garage so i just swapped all parts to another case. Also changed gearing 23/38, i think it is littlebit too long, when there is 20cm of pow it wont go over 150km/h, need to find hard packet rail to go faster.
Allmost all pipes are now welded, need to sand them and paint. Maybe i need to weld some spring mounts, but let's see ��
Also went to watch local snowcross race, i still wish that there could be some triples racing, that sound is just so amazing.
A couple of bucks
I take it that you have a redhead.Bought some Hauck Venom head
Stock Viper 700 engine, or what do you mean? That head is with six bolts per cyl, not five like redheads?
A couple of bucks
Venom as in .... Viper body w/ a redhead? Or did Hauck call them Venom?
A couple of bucks
I got cha. I did not know there were Viper heads out there w/ the Venom name.
Old folks get confused sometimes....
I would know! Lol
Some video of yesterday ride. Need to make better battery mount, it is now inside bench with some "truck bed". I have also new seat, i post picture when its ready
Added new seat, need to make littlebit lower mounts so then it fits nice. Unfortunately my primary clutch blow... Those heel clicker weights were bust and maybe those parts make some hole on clutch body. Maybe i can find some clutch frame, but it is impossible to find any heel clickers in here... Maybe i have check ty classifieds section to find some parts and hope sellers are able to send it here. I really want to test my hauck 780 engine in this season
Well i found some clutch, but if you have heel clicker weights and able to sell, please send pm message!
I still want to ride on this season!
Here is some pictures of ski fixing project.
Starting point, first i grind all surfaces with grinder. Need to get those clean.
Then i added some PE plastic pieces and weld them all around, because i need to create a shape for ski and grind a lot of material off.
Plastic welding is very accurate job, you need to check temperatures all the time. If that plastic "oil" comes to top of material, then it is ruined.
After plastic welding i drilled new holes for driver iron and then i grind skiis bottom so they look like a original.
Because skis were from skidoo or actually mountings were from skidoo so i need to make 10mm plastic spacer under rubber. I also put some screws to keep it together.
Yamahas ski pivot is littlebit wider so i grinded 1mm on each side to make it fit properly.
Finished product.
Some youtube link of Blade skis, those are DS model so it is littlebit different.
Throw some comments what you think and also offer me some heel clicker weights
Or do i have to 3d scan those weight pieces what i have and send models to some engineering works so they can make it?
Finished product.
Wow, that's impressive. I would have thought from those original pics that they would be unusable!
Why don’t you just call the company and order a new set of heel clickers?
A couple of bucks
I have some 2-speed H/Cs if your interested.
I haven't never phoned on us companys, it is also pretty expensive. If i bought some new it will cost so many $$$ because i have to pay shipping fees and taxes + VAT of whole price so that is why i don't like that option. I would like to get some used for little cheaper.
"A couple of bucks" i send you a private message.
A couple of bucks
I'll get you a picture of them.
I might be able to help you with the initial set up of the heelclickers.
Finally got some interest to install other engine. First i took engine off and cleaned engine room a little. Then i checked frame and saw that bottom rivets that keep front cooler and frame are loosen. I need to change them later and maybe add some reinforcement and new 6.4mm rivets.
Also fixed those steering column bushing, now it is nice and "tight".
And little sneakpeak
And if engine works and i have some motivation should i build some rack steering or buy totally new sled frame for new engine. I think some srx 700 with lexan hood and long travel suspension and lynx pps skid or something like that
A couple of bucks
Insure you inspect the front bulkhead under the pipes. Cracks appears on them almost as much as our W arms.
