Yamasquaw
- Jan 8, 2005
I have had not much time to look, but does anyone have the readings for the electrical system on a 2002 Viper. In need of the ohms for the stator, plugs wires. Etc. Typical rub through symptoms but it seems all good. Lights don't work, taillight, dash, back fires , cuts in and out on cylinders.
mrholmquist
all tests at 20 deg C
plug caps 5K
coil primary 0.38- 0.46 ohms
secondary coil 5.8-7.0 ohms
Stator pickup coil white/red-white/green 189-231 ohms
stator charge coil white - white 0.36-0.44 ohms
plug caps 5K
Yamasquaw
- Jan 8, 2005
So I found a few wires rubbed through about 12" down from hood hinge. Fixed those, found a couple frays up by coolant tank. Fixed those and machine is still running the same. Stator ohms were showing 1.6-1.8 at times, then other times its showing 0.6-0.7. The #'s seem to keep varying.... I hate electrical:}
super1c
Super Moderator
Did you pull harness out from under engine?
