yamrx1@cox.net
01 srx power valve pull through, can I get these fixed? Or am I buying new ones? Thank you!
A couple of bucks
SRXChris
I drilled mine and inserted roll pins, they held up good.
drew24
I did the roll pin method last season and this season when I checked them I had one that the roll pin rotated a bit and almost sheared the cable off. Maybe putting locktite on them when you put them in would be enough. Not sure. I am going to have a machinist do mine with the stainless insert so I don't have to worry about it again.
