A couple of bucks
What is compression at?
White & Nerdy
All three are just under 120 psi. After a lot of reading on here, I think I'm going to replace the fuel lines, filter in the tank, plug boots, and check the stator, since I know none of this has ever been touched (I'm the original owner). Is there a good online source for these parts? Thanks!
Where is pulse lines, I'm having same issue on 04 Viper. Spark and plug seems wet. Cleaned carbs and center cylinder seems dead. Pull on wire while running with no change. Compression all equal
White & Nerdy
I don't know about the pulse line, but mine ended up being the plug boots. It's weird, because when I checked spark it seemed okay, but after I changed boots, it ran fine.Where is pulse lines, I'm having same issue on 04 Viper. Spark and plug seems wet. Cleaned carbs and center cylinder seems dead. Pull on wire while running with no change. Compression all equal
