Just bought an 04 Viper S. Guy had (thankfully) just studded the track then didn't drive it much. There are a few nicks in the rear heat exchanger, none in the front.
I have read guys drop the tooth count on the front track drivers and regear the chaincase. Not looking to invest that much at this point.
I talked to the guy at Hauck as I read on here that he used to make heat exchanger protectors. He no longer does and said you can only run slightly over 1" studs on a Viper. Anyone running his guards? He made it sound like they wouldn't be that hard to make.
I'm not sure how long the studs on mine are. I may pull one and look for a part number and measure.
Track has 4000 miles on it so someday may be time to buy a new one which at that time a guy could get a 1" track and stud it and maybe be fine?
Thoughts? Leaning on pulling the current studs to prevent further contact with heat exchangers.
Although season is likely over here so will have all year to do something.
