Bronc_twister
I've been contemplating this swap and wondering if maybe just getting some lighter aluminum bodied shocks and extensions to go from my 151 track to probably a 162 would be just as good? I believe the M-series skids are significantly lighter but I could be mistaken. Maybe get some different rails and shocks for my skid?
m series 153 skid we just mounted in my brothers sled was 27 lbs lighter than the 141 pro-action we removed. I think it was 45lbs total. That was a 2010 model with floats. I don't know what a pro mountain weighs.
We did the 153 mounted in stock front hole and used one of the factory holes on the rear bracket, then used a 162 track and some antistabs. Dropped over 20lbs while gaining 21 inches of track.
btw if you need a longer tunnel extension for what you are doing I have an extra new one.
jordanfehr96
Pro-mountain is about 2lbs lighter than pro-action. That's comparing 144 to 141.. So you should be dropping a significant amount.
