Weatherbyman
The thing to watch for in the future is cracks in the primary sheave. Usually the stationary sheave is the one that cracks. Heat from excessive belt slippage causes this as was mentioned. Over-rev does not always cause excessive heat depending on the cause of the over- rev. Lots of things can cause excessive slippage. Worn belt, snow intake, dirt, oil, water etc.
I don't know what shape the primary is in but I'll bet there is still a lot of good stuff you can salvage. The weights are probably good as well as the rollers and even the spider.
A person has to be careful with sleds with reverse. Backing up heats the primary and drive belt right away because there's very little secondary load.
These Yamaha sleds are easy to fix with respect to clutches. Lots of interchangeability. Just get it calibrated correctly
And you're back in business.
Good luck.
Good luck.
