Honestly you probably don't need 8 tooth drivers. I did a bunch of simple mods to my 700 redhead Venture and it surprised the heck out of my buddy who rides an Ski-doo 800 E-teck Renegade and another who drives an Artic Cat 800 Crossfire. The response of my sled is awsome, and I run stock gearing, 9 tooth drivers with an aggressive 136" Cobra track.
Simple mods and basic maintenance that add up to alot,
- Apex or Rx-1 Helix , stock secondary green dot spring set to 80 rap on hardpack and 70 for soft fluff, or slushy stuff.
-One layer of headgasket removed for slightly higher compression ratio
-Reed stopper notches on stainless stoppers, ( or reed spacers)
-Home made transfer rods ( or baught ones) way better traction
- Rebuild and calibrated my clutchs to run proper WOT Rpms ( 8500 rpms)
- Properly, cleaned, and tuned carbs
-I removed my starter ( it failed), battery and ring gear
Removing the heavy ring gear reduces rotating mass and helps the motor spool up faster for better response
