Viper 2 1/2 lug
ratpack
frewsburg ny
How do I get the clearance at the drivers for a 2 1/2” track. The 7 tooth 2.86 is the same diameter as the 8 tooth 2.52.
I looked into doing that at one point, 7 tooth 2.52 should leave enough clearance but not by terribly far and thats a pretty tight bend. I ended up doing an ekholm tunnel drop and roll. Used parts are the only affordable way to go, if you can find them. There was 3 sleds for sale around here that had those parts this spring.
