trevor1203
I am planing to modify my sled this summer in time for winter i have a 97 vmax 700 sx and i am planning on installing cpr triple pipes and reed spacers. looking for either a clutch set up or a clutch kit i can install. i am looking for more of a aggressive trail set up so in other terms i kinda want a best of both worlds kinda deal. so i was thinking a higher engagement spring to get a better take off without sacrificing any top end. i also need to increase my rpm to around 9100 which is required for the pipes i have. also any top end upgrade i can do either from clutching or any other modification would be greatly appreciated. Thanks in advanced.
I would have to do some digging but I had those pipes on an SX-R and I think I have a good starting point.
trevor1203
Thanks any info you can find would be greatly appreciated.
8AY weights inner hole empty and the out hole a 3.1 Gram, P-P-P primary spring, 48/43 Helix with a Silver Secondary spring set at 80 deg.
trevor1203
Sweet thanks by any chance do you remember how the sled ran like to rpms and when did it engange? also how was the speed. also do you have any idea where i can find those wieghts
Thanks again
Thanks again
A couple of bucks
We do have a “WANTED” section of the classifieds. Swaps meets in the fall too.also do you have any idea where i can find those wieghts
Thanks again
Direct from Yamaha or as stated in the wanted section.
Its been a while but I think 3800 engagement and WOT 8350 to 8400.
A couple of bucks
How far up in cheeseville are you Trevor?
P.M. Dale here ... https://totallyamaha.net/member.php/12512-NickyTech
He’ll hook you up.
He’ll hook you up.
trevor1203
im located right around the milwaukee area
A couple of bucks
Should Nickytech (aka Dale) not have you needs, there is a quite large swap meet & drag race down at Belvidere in the fall.
