WonÂ’t pull rpm
Those are Vmax-4 weights, alotta people run those for racing.
Yours must be loaded up a little too heavy on the rivets.
If it was mine, I would try and find some stock weights with a stock spring.
Will be tough to tune the clutches without knowing the spring rates of your orange spring.
If you do go back to stock in the primary, you MAY be able to use that hauck A helix.
Here is a set of 1999 Srx 700 Weights with rivets, may be the easiest and most cost effective way to go.
https://www.ebay.com/itm/98-99-01-Y...862644&hash=item33f22c8bac:g:uuMAAOSwri5bdrUD
Then it calls for a Yellow/White/Yellow Primary Spring PN 90501-603L2-00
https://www.ebay.com/itm/Yamaha-905...357032&hash=item3f94d10f86:g:CwkAAOSwnApZ5Mgg
With the secondary, they call for a red spring for the 1999 spec, with a 60* twist.
If your secondary spring does not have a small paint mark, I would replace it as well.
Ok so I ordered those weights and primary spring. Do you have a part number for the secondary spring?
That says it is stock for a 98. Just want to be sure this is the one I want? Thanks
Ok sorry. I found where it is also listed for the 99. I ordered it. Fingers crossed the set up works better than what I had.
Also someone in here here said I am losing performance with the mbrp can I have on my sled. Can you confirm that my stock muffler would be better performance and what about a bender can??
You may lose a couple hp with the silencer, but will have nothing to do with what your describing.
This setup will work well for you.
