NorthofSixty
Thanks Main. Just by luck I found one yesterday along with the steering arms. Picking them up today so I should be in good shape to finish the front end.
NorthofSixty
Some of the trouble:
Seized piston needed a little persuasion.
Con rod bearing has seen better days. Explains that knocking sound.
Crank and rods are good. Just need new bearings and thrust washers.
Never trued a crank before but I guess I'm gonna have to learn.
Airbox needed gutting for the Vmax 600 carbs to be of any use.
Lot's if paint stripping
Cans are done and 1-1/4" track is in. Need to decide whether to shorten the sway bar or lengthen the torque arms to work with the longer steering arms and struts.
Cans are done and 1-1/4" track is in. Need to decide whether to shorten the sway bar or lengthen the torque arms to work with the longer steering arms and struts.Vincent
Well-known member
Nice build
NorthofSixty
Question for anyone who has done the flatslide carb conversion. Did you leave the lower baffle tube in place when you gutted the airbox or does it need to be removed or modified as well? Any advice would be appreciated.
