I know this has been asked many times but my son is racing his enticer and ld like to put a 36 mukuni round slide. My qeustion is can anyone give me a starting point for the carb jets and what not. The motor is stock but freshened. Thanks for the help. At sea level.
Yikes.. wish I could but I would not want to take the risk and send you down the wrong path and hurt the motor. Starting from nothing is a bugger.
did you check the rules if that is allowed? some race series do not allow a carb change.
there is a post in the vintage about a guy that put a flat or a round slide on a 340 ovation from overseas.
found it. https://totallyamaha.net/showthread.php/85031-ET-340-engine-with-Mikuni-VM-34-carb/page2
i would suggest a round or flat slide single carb from a doo 377, polaris 340 or cat 340 as it should be pretty close to what you need.
