D duwem Member Joined Mar 12, 2018 Messages 85 Location WI Oct 9, 2018 #1 Putting a new throttle cable on the 04 Viper S. How do I get to the end on the oil pump, looks pretty buried. Thanks
super1c Super Moderator Joined Sep 15, 2003 Messages 5,492 Age 54 Location Freeland & Otsego lake, MI Oct 9, 2018 #2 You have to take the rear mag side motor mount off to get at it. The motor mount comes out easy then oil pump right there. Last edited: Oct 9, 2018
D duwem Member Joined Mar 12, 2018 Messages 85 Location WI Oct 9, 2018 #3 What needs to come off prior to the mount?
super1c Super Moderator Joined Sep 15, 2003 Messages 5,492 Age 54 Location Freeland & Otsego lake, MI Oct 9, 2018 #4 duwem said: What needs to come off prior to the mount? Click to expand... Airbox, carbs for sure. I don’t remember but I don’t think you have to take mag side reed cage out.
super1c Super Moderator Joined Sep 15, 2003 Messages 5,492 Age 54 Location Freeland & Otsego lake, MI Oct 9, 2018 #5 And that was mag side rear motor mount. Fixed in previous post
D duwem Member Joined Mar 12, 2018 Messages 85 Location WI Oct 10, 2018 #6 Should I just adjust to match what's on there for the pump and carbs or is there a procedure?
super1c Super Moderator Joined Sep 15, 2003 Messages 5,492 Age 54 Location Freeland & Otsego lake, MI Oct 10, 2018 #7 Should be no adjustment needed on carb other then 2mm gap at throttle before carb slide moves. I always go a hair more to make sure torrs doesn’t kick in. Oil pump cable should have 21 +/- 2mm gap when cable is fully pulled out at adjuster. Attachments CFC58F32-CC83-4CFA-8E76-F739E2F93A54.jpeg 13 KB · Views: 41
