Changing Throttle Cable, Access to Oil Pump End?
duwem
WI
Putting a new throttle cable on the 04 Viper S. How do I get to the end on the oil pump, looks pretty buried.
You have to take the rear mag side motor mount off to get at it. The motor mount comes out easy then oil pump right there.
Should I just adjust to match what's on there for the pump and carbs or is there a procedure?
Should be no adjustment needed on carb other then 2mm gap at throttle before carb slide moves. I always go a hair more to make sure torrs doesn’t kick in. Oil pump cable should have 21 +/- 2mm gap when cable is fully pulled out at adjuster.
