Mrvmaxxtc
For some reason, I thought I needed to take out my starter relay. Now I dont remember what wires went where. Or what way the relay went in. Could someone give me a pic of their starter relay in their vmax so I can see how to wire it? Thanks
super1c
Super Moderator
There should be a “B” and a “M” on the relay. B to battery, M to starter motor.
Mrvmaxxtc
I do not see anything unless its worn off or something one kf the posts has a washer attatched to it. If someone could figure out which one went to the post with the washer on it id be golden.
super1c
Super Moderator
This pic should do the trick! Relay orientation should all be the same!
Mrvmaxxtc
Thanks man. Just what I needed
Mrvmaxxtc
So I got it put in correctly. Ans I crossed the posts on the starter relay with a screw driver, and the engine turns over. Does that mean my starter relay is bad?
Yes, I think so.
Ensure that the "signal" wire from the key switch down to the relay has power when you turn the key to the start position and obviously clean terminals.
super1c
Super Moderator
Are you saying nothing happens when you turn key? Only when you jump relay posts it works? Check fuse, just replace fuse. Seen them bad even when they looked good.
A couple of bucks
