These studs are too long for 01 srx? Limped speedster track
j2hizzo
southern maine
Running a speedster track half inch lug. Initially thought these pencil picks would be fine but they seem too long. I'm wondering what length I should go with all chisel studs?
The amount of rubber molded were the track clips are and will rub on the tunnel protectors tell you were you can run safe. It does change from one track maker too another so keep that in mind when buying.
Can I use a push through stud on this track or should I stick with the screw in stud? I'd like to use a pushthrough
