bluewho
The amount of rubber molded were the track clips are and will rub on the tunnel protectors tell you were you can run safe. It does change from one track maker too another so keep that in mind when buying.
I'm thinking a 3/4 chisel would work
Vincent
Well-known member
I think that would be perfect.
Can I use a push through stud on this track or should I stick with the screw in stud? I'd like to use a pushthrough
