Vmax xtc 1997
My project!!!! a first for me. Purchased a 02 viper last spring with a blown cylinder, thought it would be a good learning experience to make the repair.
So here I am, working on removing the engine.
Plan;
split crankcase make sure no unwanted pieces have fallen in there and replace bearing/oil seal.
put new gasket, oil seal, bearing everywhere... (jackshaft,driveshaft, speedo).
new rings, wrist pins, needle bearing and replace middle jug and piston.
new track.
clean carbs.
Should I be careful or spend some time on other area on that sled? i.e; gas filter in the tank? oil pump?
some of you guys already told me to put an opticool gasket, rear cooler.....
All advices are greatly appreciated
Vmax xtc 1997
grrrr sorry for upside down pic
A couple of bucks
Insure proper end gap on rings. Also, do Viper rings have a certain side of the rings that are positioned up or down. I remember reading about a very small groove on one side of the ring and none on the other side.
Please keep in mind, I've never owned one.
Vmax xtc 1997
Hi Couple of Buck,
I remember to reading about it but not sure for which sled it was. I will find out for sure! thank you.
Now step one achieved; removal of engine
While struggling to get the engine out I noticed that spring in the bottom of the cab, anybody have a clue it came from where?
Now going in!!!!! split crankcase
Was probably on the outside of a oil line connected to the crankcase to keep it from kinking.
That's how they come, Im sure it just slide off the line when hose was pulled.
Vmax xtc 1997
Thank Murder! It make sense.
Vmax xtc 1997
Just got out of the operation table!!!
1- any idea why all the middle reed petals are chewed (top facing side)
2-crank toasted? the free play seem out of specs and the middle rod bearing is definitely not rolling properly and some free play from side to side as well as up and down. it did scratched a bit the bottom of the crank case (picture)
Vmax xtc 1997
that middle rod bearing is toast. i would plan on the rod being bad as well. get the others checked and replaced as needed. as you are from quebec, i would be wary of cv tec as they robbed a crank of my brothers of the good parts to build another customers crank. yamaha canada listed that as a whole assembly. yamaha usa listed all the parts seperately.
Vmax xtc 1997
Thank you Maim.
I am always a bit scared when having some work done that I cant see the process from my own eye.
any other place you know of?
there is a guy in southern ontario that does them as well but i cannot recall who it is at the moment.
hopefully someone else will chime in. good news is you can use a 2000-2002 srx crank in there if you come across one. turns it into a torque monster as my brother ran one for a few years after the cv incedent.
Vmax xtc 1997
Probably need some other mods to accommodate that change? It just drops in place perfectly?
A couple of bucks
As long as everything is torn down to parade rest, SRX/Viper reeds will drop in there with not a whole lot of grinding w/ your Dremel.Just got out of the operation table!!!
yup, just drops in as cases are same part # for both.
Vmax xtc 1997
Nice thank you for that info!
Vmax xtc 1997
Hi,
not sure I understand the first part **As long as everything is torn down to parade rest**
and what exactly do you suggest to grind?
A couple of bucks
SRX/VIPER reed cages will fit into there respective position on a redhead w/ minimal grinding. Just a little bit needs removed inside.
Its a Viper to begin with Dan, the Alzheimer's setting in already ?? Lol !! j/k....
A couple of bucks
Good lord!!! I was paying attention to his screen name.
Vmax xtc 1997
hahaha!!! no worries, but indeed I switched my reed cage in my vmax for srx one like you had suggested me last winter
but now I am working on an 02 sx viper with middle cylinder blown. I wanted a project that would make me work alot and learn.
I am wondering what could have caused the middle reed petals to be destroyed at the tips????
