A couple of bucks
I .....misplaced my share of brain cells in the 80s.Its a Viper to begin with Dan, the Alzheimer's setting in already ?? Lol !! j/k....
Vmax xtc 1997
Vmax xtc 1997
update:
pistons, power valves and cylinders all clean!
crankshaft installed
crankcase sealed
new cylinder gasket installed with permatex red spray gasket
pistons installed with new bearings and c-clip
cylinders bolted back on
all lubed with assembly lube
Now waiting for that opticool head gasket and read/do my homework about the power valve...
crankcase sealed
A couple of bucks
Properly setting orread/do my homework about the power valve.
https://totallyamaha.net/showthread.php/77037-Pull-through-prevention-with-pictures
^^repair^^
Vmax xtc 1997
Properly setting or
^^repair^^
Great thank you, very good to know!
Vmax xtc 1997
Vincent
Great thread! Excellent documentation.
A couple of bucks
You'll feel satisfied that all is up to snuff.Carbs cleaning!!! all new gasket and received new fuel/oil lines, clips and carbon tech reeds
https://totallyamaha.net/showthread.php/97649-96-XT6-to-144
^^post #21 & #47^^ for a secondary fuel filter.
Vmax xtc 1997
thank you,
first time doing all of that, but with the help from the people here and info from older threads it does help alot!
Vmax xtc 1997
Hi Danny,
yep it is part of my project to put a new filter, but did not thought about the secondary inline fuel filter. I will definitely look at that.
thank again for the advices
A couple of bucks
Updates?
Vmax xtc 1997
Updates?
hahah sorry I had not been here for a wild... YES UPDATE
crank rebuilt
new rings on all pistons+clips+bearings
new carbon tech petals on all
new carb kit rebuild on all
new gas filter
water pump rebuilt
new gas pump
had lots of problem to start from dry carb/fuel but found a thread on here about same issue and did what it said and finally got it to run!!! LOTS of smoke
But seem to still have minor issues....
when trying to initial start I was putting a bit of mixed gas in all 3 pistons, would star and stop.... I had to repeat the process 5 or 6 times before it would begin to start on only 1 crank pull, but in the process of removing the the plugs and putting them back I noticed a weird color in the middle and clutch side plug ( grey stuff in the picture) Any idea what can cause that?
Also some kind of irregularity in idle.... see video. An odd puff coming for the muffler few time. well you tube wont let me upload at the moment
smoke come out normally and every 10/20 seconds it seems like just a puff of air gets out.... like if no oil had been burnt for 1 stroke....
I also have an error message blinking Item;
-Y.P.V.S. Condition - Disconnected Short-circuit Locked This I guess I can resolved with the manual and some thread search here.
And one last problem I think I have a small crack in the header, middle part, I can see some tiny puff of smoke come out and seem to be a bit of oil spitting as well....
Vmax xtc 1997
ok so after talking with other guys, the huge constant white smoke would be from coolant entering the combustion chamber....
learning my first build the hard way
can a opticool gasket be placed up side down (wrong side up or down) not sure how to word that..... cause a leak of coolant?
I do I have to reopen the entire motor to make sure it did not went into the base......
Vmax xtc 1997
UPDATE.
Coolant reservoir emptied it self. I assume the base is probably full. back to square 1. Remove engine/open/clean.... and try to figure what is leaking...
