Hello everyone,
1.) so I just tbought this 02 viper and the power valves are missing 1 screw on 2 of the power valves and 2 screw heads are stripped so i tried to drill them anyone have any ideas how to get these out.
2.) after i hopefully get all of these out and clean them do I need to ajust them if so how do i do so?
-mason
-mason
SRXChris
Ok so it is the bolts on the cylinder jug which is picture one correct? I would post a picutre but i cannot get it to work.
Hello everyone,
-mason
you can try vise grips or what i've done in the past is used a dremel tool and put alittle slit in the head and used a flat head to get them out. just be careful that the only thing you cut is the bolt
SRXChris
If you can get an easy out in there it may help, not sure how far you drilled the head of bolt in though. I snapped the bolt off in the jug on mine it wasn't fun.
A couple of bucks
This works well. Cut the slit 1/2 way through the head and just barely the thickness of the straight slot screwdriver you will be using. Roughly a 1/16" thick slot. The screwdriver you need to be using should be at least as wide as the bolt head.
Allen head bolts are a good replacement for any bolt that would benefit from a positive grip head. A stripped head is pretty much a thing of the past.
The proper type of anti-seize is beneficial too. There are 1/2 a dozen(ish) different types of anti-seize dependent on the metal your securing. The nickel formula has the highest temperature rating for ferrous metals.
A couple of bucks
DIY power valve repair.
https://totallyamaha.net/showthread.php/77037-Pull-through-prevention-with-pictures
