Well, I thought while I had my carb rack off it would be a good idea to see what my fuel screws were adjusted at. WRONG. They were all tight and when I finally broke one loose I found out that I actually broke it instead!!!! I thought I was racing my first radar run tomorrow morning, but maybe not. Is the tip still where it was before?? Can I still run it? Or is there a danger of sucking it in the motor? F#%k, this is just like my entire life goes, if something bad can happen it will. I spent a butt load on ice picks, transfer rods, jetting, and such just for tomorrow too.
SRXSRULE
- May 2, 2003
Can you post a better picture? The fuel screws should not be hard to turn at all. They just have spring pressure and an o-ring that keeps them from turning. Maybe you removed something else? ===SRXSRULE===
skidooboy
almost looks like a pilot jet. ski
SRXSRULE
- May 2, 2003
It looks gold colored in the picture but fuel screws are stainless, also the threaded portion looks too long for a fuel scew. Not sure what you broke, or didnt break. ===SRXSRULE===
Here it is
My digital will not take a good close up. I found this picture in the tech pages and circled the one I took out. Different carbs, but the same screw location.
ekimsx600
Isn't that the drain screw for the bowls?
SRXSRULE
- May 2, 2003
Ah...you broke the float bowl drain. Chances are you can screw it back in and be ok. Its a tappered hole so the broken piece cant go anywhere. Now....Dont take this the wrong way, but if you dont know what your doing, better to leave it alone. ===SRXSRULE===
Sorry, I was always under the impression that the idle adjust screw was that one. I've rebuilt motors and never had to mess with them. Main jets and needle adjustments I can do, but I guess I need to know where the fuel screw is. I know where the air screw is, but thats different, isn't it? I circled what I believe is the air screw. Or is the air screw and fuel screw one in the same?
SRXSRULE
- May 2, 2003
Thats the Air Jet, a fixed orfice not adjustable. There are no air screws on these carbs. The fuel screws are on the bottom of the carbs and should be around 1.5 turns out on your 01 SRX. I think I have a picture somewhere. ===SRXSRULE===
Yes, MrViper700 did my porting and he said 1.5 also. Is it on the bottom of the float bowl, or inside the bowl? I just don't want to turn the wrong thing again.
SRXSRULE
- May 2, 2003
You dont need to remove the bowl. Its right next to the bowl, small head flat blade screwdriver is needed, the small screw is slightly countersunk into the carbs. ===SRXSRULE===
Steven DeMarco
- Feb 16, 2004
honestly I am not trying to sound mean, but you really need to spend the 45 dollars and get yourself a service manual. this will save you a lot of grief.
Good luck
Good luck
yamaholic22
all of this is on the tech pages as well
ViperTom
I agree with Steven...get a service manual. Soooo much valuable info.
it is on the out side of the bottom of the float bowl. I look for a pic. there will be the 4 screws to take the bowls off, and then there is a bigger screw, turn it in till it is lightly seated, then turn out 1.5 turns. Maxdlx
