Phazer_Schmidt
So my Dad's 89 Phazer he picked up is having an issue bogging under load. Got it last year, didn't run it much due to the fan belt being off. Fixed the fan belt, cleaned the carbs and updated with the 80L primary. It starts up and idles great but bogs and almost dies when you try to give it throttle. I pulled and greased up the skid, that seems to be fine, track tension seems right. Put a new belt on, it is about flush with the top of the secondary clutch. Still have the same issue. Lifted the track up, that doesn't change anything. Took the belt off and then it would rev up fine.
I am thinking it is clutch related but not sure, wanted some opinions. The clutch is most likely stock but I didn't look to close. Any ideas?
