hereismylife
Going long track and need to put exchanger on. The viper one is curved and the srx is flat.
Why does everyone use the srx vrs the viper cooler?
I used the tracks usa tunnel extension with the srx cooler and it just fit on my build a few years ago. Just fit meaning it doesn't hang down past the extension. Having said that its more of a generic tunnel extension that you have to cut holes and finish. (used the oem long hose covers) Its not like a Hartman extension that looks factory. With the Hartman or OEM extensions you need the mountain cooler because the end taper is a-little slimmer. I wanted to keep the srx cooler. Good luck.
